Use the following procedure to add entries for devices with static IP addresses to the DHCP binding table.
- Select DHCP Snooping.
- Select the DHCP Bindings tab.
- Select Insert.
- In VlanId, type the VLAN ID.
- In MacAddress, type the MAC address of the DHCP client.
- In AddressType, select a value.
- In Address, type the IP address of the DHCP client.
- In Interface, select a port.
- In LeaseTime(sec), type the time in seconds.
- Select Insert.
- Select Apply.
DHCP Bindings Field Descriptions
Use data in the following table to use the DHCP Bindings tab.
Name |
Description |
VlanId |
Specifies the VLAN to which the DHCP client belongs. |
MacAddress |
Specifies the MAC address of the DHCP client. |
AddressType |
Specifies the type of address. The default address type is IPv4. |
Address |
Specifies the IP address assigned to the DHCP client. |
Interface |
Specifies the interface to which the DHCP client connects. |
LeaseTime(sec) |
Specifies the lease time (in seconds) of the particular DHCP binding entry. The time range is 0 to 2147483646 seconds. |
TimeToExpiry(sec) |
Species the time of expiry (in seconds) of the DHCP binding entry. |
EntryType |
Specifies the type of the DHCP binding entry.
